The MS8268 multimeter has worked fine with no issues, but it's been in a drawer for several months.
Batteries had corroded, but the contacts appear to be fine.
I tested continuity and the battery clips seem to be okay. Opening the case there doesn't appear to be any corrosion and the springs look like they are contacting the case.
Cleaned out what little corrosion had come off batteries from terminals, but it doesn't turn on with fresh batteries.
Is there a reset or anything else you can suggest?
Thank you in advance.
