C
coxy84
any one had much experiance with using master and slave dimmers to switch and dim the same light from both switches.
are the just wired the normal way with 3core?
i belive varilight do them
No, they're connected together with 2 core. The master is obviously the dimmer, then each slave switch (you can have as many as you want) is a retractable (momentary) switch.
master and slave
Australia
coxy84,
SMB,
