DrewSN
Hi there,
Does anyone know the name of the 'shroud' that would go over a mains supply cable before entering the fused cutout, typically on a TNCS supply. This item is black, rubbery and 'Y' shaped to fit a 2 core cable. So far I have been able to find heat shrink tubing but I would like to find some sort of shroud to go over a 2 core 16mm SWA before it enters a private metering system that doesn't need to be heat shrunk. The supply is a TT system, therefore the steel wire is redundant but bonded at the other end. Thanks
