K
kmatthews
a capacitor of 100uf is connected in parallel with a 20ohm pure resistor. the group is connected to a 200v 50hz supply calculate the power dissipated in the combination. the answer is 2000w but i dont know the workings out anyone please?
is it as easy as p=v2/r im sure there is more than that.
As they are in parallel you can effectively ignore the capacitor, so you are left with:
V(volts) = I(amps) x R(ohms) therefore I = V / R so I = 200 / 20 = 10amps
and
P(watts) = I(amps) x V(volts) therefore P = 10 * 200 = 2000watts
Hope that helps.
Upvote 0
Hey i answered this one late last night with the same answer on your gola question thread when i was the worse for wear from beer and still got no thanks! :rolleyes:
Upvote 0
maths question
Electrician Courses : Electrical Quals
kmatthews,
lee sandland,
Electrical Courses
