Maths | on ElectriciansForums
Discuss Maths in the Australia area at ElectriciansForums.net
skystorm
Hi all back on night shift
A conductor has across-sectional area of 20mm2, a lenght of 48m and is made of material with resistivity of 0.02 u ohms m .Its resistance is
R is resistance in ohms, rho is resistivity Ohm m , l = length in m, A = csa in m[SUP]2[/SUP]
Calculation is R= rho l/A
You have resistivity in microohm m so divide by 1,000,000
You have area in mm2 so divide by 1,000,000
length is in m
R= (rho/1,000,000 (*l))/(A/1,000,000)
rearrange a bit and the millions cancel out so R= rho(in microohoms)* l (in m) / A (in mm2)
Therefore R = 0.02*48 / 20 = 0.048 ohms
perhaps; similar situation to tel!
teletrix you know im going to be a star in the electrical world, going to chase walls today and the boss wont hire wall chaser and said use a kango with chisel just, any tips as i havent done this before
try and avoid waste pipes.
Reply to Maths in the Australia area at ElectriciansForums.net
Check the clearance between the back panel and/or terminal cover that you've removed. Look for small burn marks.
J
Tiling over screed/plywood floor with height differences. Hi guys. Im a carpenter who has tiled a fair few floors over the years as i fit a lot...
Johnny
J
