C
Crashman
I'm working on a house that has no gas or oil, and it would not be easy to get bottled gas to it.
So here is my problem, the client wants everything electric.
So in his ideal world that would be:
2 x 9.6kW Instant water heaters
1 x Reasonable electric shower, say 8.5kW
1 x electric hob
1 x electric oven
and probably 5 x 2 or 3kW convector heaters.
Plus rings and lighting for a 3 bed house.
At the moment there is only a pretty dodgy 60A supply that will need upgrading even if it was to remain at 60A just because of the state of it.
The way I see it, which ever way you try and apply diversity you don't come anywhere close to getting under 60A!!
Does anyone have any bright ideas? Other than to walk away from the job!!
My knowledge of 3 phase is fairly limited, but I believe it could handle the required loadings if the house was to have it installed, but it it a realistic option in a domestic setting??
Rob
1 x electric hob
1 x electric oven
Rob
