This may sound abit dumb, But looking at a small office with new install of dado trunking 7 sockets, only supplying 3 desktop pc's 3 LCD monitors and a 36 inch LCD Monitor, these running might be odd mobile or laptop plugged in now and then. what i was concerned was that is run off a RAdial 2.5mm T&E on 16amp breaker. If I done the x by 0.4 trick would be fine and within the be ok as far as demands, but im thinking there is still too much for this circuit. what diversity would i apply? i SEEM TO HAVE LOST A BRAIN.
thinking (this approx) 3 desktops are max 250w each LCD small ones 75w each and 36"150w.
would come out nearing 5amps
but if i apply the 100% of largest point plus 40% of every other point, we are sky high..
any takers?
load wise i would run a 2.5mm 16A radial, BUT with IT equipment run in a separate ring cpc and connect high integrity earthing.
4mm good idea. if all in trunking you can use singles. and use 4mm cpc.
yeah basically this is in and done already, i was checking it out and had few ???? run through my mind.... as far as the high integ and sep earth ring, ideas how to achieve this with the 2.5 t&e already in place. would i run another cpc in..? would i be correct in understanding its because the earth leakage we talking about on this equip that could require this high integ earthing..
been years since i looked at office requirements, I remember 15 odd years ago doing Loydds in london we had the floor boxes on copex and plug adpts going to power track with the extra earth (thinking back i believe was something to do with this for sure)...last time i delt with this!
Max demand for radial in office
Australia
Robinson,
Robinson,
