Max distance cable can run overhead without support | on ElectriciansForums
Discuss Max distance cable can run overhead without support in the UK Electrical Forum area at ElectriciansForums.net
Northern Ireland
Hi folks,
I have been through the regs. Have a garage wired from a house. Cable runs overhead at an appropriate height and is suitable cable. The distance in mid air is about 2m. My question is does this need mechanical support by way of a conduit or tray. It does seem a bit excessive for that distance. Cable does not under tension. Any guidance would be helpful.
Reply to Max distance cable can run overhead without support in the UK Electrical Forum area at ElectriciansForums.net
Hi folks, I have been through the regs. Have a garage wired from a house. Cable runs overhead at an appropriate height and is suitable cable. The...
And if it's a garage then use metal clad accessories.
