Max neutral/earth voltage | on ElectriciansForums
Discuss Max neutral/earth voltage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
B
Big Al
Hi guys,
It's been 10 years since I was a sparky so I am out of date with current regs. Can anyone tell me the max permitted neutral to earth voltage at a spur. I think it is 1.25v. Please help!
Pme its is required that on a permant install in fault condition nothing greater than 50v n-e
tempory installs and caravan parks/marinas/building sites nothing greater than 25v n-e (obvosioly not pme as this is not permitted on anything that has a safe n-e toch voltage of less than 25v
no volatage should be present on a n-e test if there is u either have bad insulation restance beteween n-e earth /bad wiring or a surge protector that has activated
i hope this helps
Reply to Max neutral/earth voltage in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
They ought to be able to check for the voltage going completely off using one MCB off at a time to confirm that. That would be my assumption...
As above, check the whole cable run and look for damage or any junction boxes that might have trouble inside them. Water getting in is a common...
