Max number of sockets allowed on a radial circuit in order to comply? | on ElectriciansForums
Discuss Max number of sockets allowed on a radial circuit in order to comply? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
Oldham
Hi all,
Just wondering if anybody knew why the max number of sockets you can have on a radial circuit covered by a 20amp breaker, and fed by 2.5 T&E in order to comply with regs?
Cheers
Hi all,
Cheers
Appendix 15 BYB Page 453 is your guide, if you have a copy that is.
This sounds like an enquiry about a specific job and I think using the forum as an alternative to having a copy of the regulations is very bad practice. You've no way of knowing if the answer you're given is accurate so I'm going to close this thread. Rather ring your scheme helpline for advice, at least you'll be able to get a reference number or something to verify the accuracy of the info.
Reply to Max number of sockets allowed on a radial circuit in order to comply? in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It’s difficult to advise on an electrical issue when some isn’t very conversant with electrical terminology.
One thing you may find is that it will most probably be a 6mm cable and to get two of them in to a terminal may prove to be a stumbling block if...
