Max permitted Zs values... | on ElectriciansForums
Discuss Max permitted Zs values... in the UK Electrical Forum area at ElectriciansForums.net
Baddegg
Supporter
Patron
Southsea
Anyone know where I can find max Zs values f
[ElectriciansForums.net] Max permitted Zs values...
or these?.....and the 6a LN 5906....
Thanks @Andy78 think I’m over thinking it, never come across them before.... the main switch ln550 appears on the drop box on the software I use whereas the mcbs don’t...
[automerge]1578851669[/automerge]
Thanks @Wilko.....confusing myself with BS numbers! ?
That sounds some very specific software if it refers to the device by serial number.
Only needs to be recorded as a BS3871 type 2 really.
Reply to Max permitted Zs values... in the UK Electrical Forum area at ElectriciansForums.net
Generally speaking local earthing will rarely be below a couple of ohms, so in parallel with a TN-S sub-ohm value will make little difference...
A lot will depend on the load on the tray / basket / trunking and the span before it bends / distorts
