K
keefy
Just tested property with a HUGE ring circuit and got 1.4 ohms on a type C RCBO. Given the max is .57 there is no chance of getting this close. Has anyone come across this before and what would be the advice given that it is protected by an RCBO and if you consider a TT system it is better than the usual readings you get there.I also know there has to be some consideration to ensure the device trips with a L - N fault!
