maximum demand | on ElectriciansForums
Discuss maximum demand in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
sparky16
Hi there doin project and stuck on one of the questions help would be appreciated. For maximum demand applying diversity for this Twelve 0.5kw 3 phase induction motors for car ramps each having a power factor of 0.8. efficiency 95%
toal KVA is approx. 8kVA, apply diversity (x 0.4),= 3.2 kVA I = 26A (P=1.732xIxV)
That was quick, much appreciated. You wouldnt happen too know the following two lol. thanks again
1 = One 5.5kw 3 phase induction motor for gas hot air ducting system having power factor of 0.75. efficiency 95%
2= one 2.2kw 3 phase induction motor for roller shutter door located at the south end of workshop having power factor of 0.85. efficiency 90%
work out your current I = KVA/ (voltsxroot3). kva =kw/PF. volts in this case is 3 phase i.e.400. if i do it all for you it will make you lazy. don't forget to allow for the efficiency.
Reply to maximum demand in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
There's a church in a town near me that has solved the heating problem for most days by building what is essentially a large timber and glass...
Given that a lot of EV's only charge from one phase when connected to a 3 phase chargepoint does the customer really need a 3 phase chargepoint...
