Hi
We are doing some refurbish work at my house and I am planning to run a new feed to the garage and install a DB. Mainly because I don’t trust the exciting wiring in there and I have no idea where its supplies from. Plus I would like a separate DB as I use a lot of tools in the garage and I would like to allow for future lights or power I may install in the garden.
I am having two problems.
1. I have calculated the maximum demand for the house and after considering diversity we are using around 130A. I know we don’t come nowhere near that, as there is only 4 of us in the house. I am not sure how much power we can use before it becomes a problem.
2. I don’t know if I should install a MCB in the main DB an take the feed from there or take the feed after the main isolator.
Thank you
Mo
Thank you
Mo
