Mcb cover on consumer unit | on ElectriciansForums
Discuss Mcb cover on consumer unit in the UK Electrical Forum area at ElectriciansForums.net
H
highspark
Just been to a job and the cover which goes over the MCB's is missing can you code for this?
Front cover is on no finger or tool ingress could occur etc
As above, no code as long as the IP rating has not been compromised. Seen this a few times where the CU is in a position where the cover can't be opened i.e. in an enclosure with a sliding door.
If there is the possibility of accidental operation of the MCB then make a note on the paperwork, i.e. in a cupboard where coats are hung they may accidentally knock the MCB and switch the circuit off.
Reply to Mcb cover on consumer unit in the UK Electrical Forum area at ElectriciansForums.net
I saw some videos talking about RCD's and RCBO's which is what got me curious and to realise how outdated our CU is. I think going forward I'm...
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
