mcb keeps blowing on lighting | on ElectriciansForums
Discuss mcb keeps blowing on lighting in the UK Electrical Forum area at ElectriciansForums.net
faversham
Hello sparks
I was at a Job earlier today,the customers upstairs lights would not turn on due to the 6A mcb operating so it's a short circuit so I disconnected the supply to the first light the supply disconnected from consumer unit ,then did a insulation resistance which came out clear tried the mcb without any connection it stayed on.so connected the supply at consumer unit and left the other end not connected to anything it stayed on so connected the loop out and switch live it all come back on for 2 poxy minutes then it would come back on .I had to leave disconnected and will be returning back tommorow . Any suggestions would be extremely grateful
You will just have to keep breaking the circuit down and testing it until you find it. Has any work been done recently? Anyone tried changing a light fitting ect? Banging in nails? Screwing up picture hooks etc?
Use the logical process with appropriate testing to find the fault.
Repair the fault.
Replace the MCB at your expense as you are likely to have damaged it by repeatedly closing it onto a fault.
Or
Employ the services of an electrician
You claim to have 2330 level 3 nvq/AM2 /17th edition and your method of fault finding is to keep closing the MCB.
By the time you find the fault the MCB will be toast. That’s if the house hasn’t burnt down first.
Dead testing is the basics of any fault finding, or even a new installation......start by breaking the circuit down until the fault is found. Instead of hit and missing with the mcb.
Not sure what to really say here tbh, this is your standard testing for a fault set-up and basic at that. I'd expect a trainee to ask a question like this but not someone who carries your qualifications.
Qualifications aside have you any practical experience in fault finding and when you did your apprenticeship were you not shown and/or taught how to, as Tony points out closing the protective device repeatedly onto the fault as part of your testing procedure shows you really don't know what your doing, use your meters they are there to safely identify the fault without you damaging your protective device or sending multiple mains transients into the network and upsetting other users on the same sub-station.
From what you describe you have not mentioned closing any switches when IR testing, so this sounds like a good palce to start since if the fault is (as is likely) at a light fitting and the switch is open then the fault will not show up.
Similarly if there are two way lights swap the switches while testing.
It's pretty much been covered by the Guys already so just learn to fault find with your test equipment and leave the Bang test alone.
Reply to mcb keeps blowing on lighting in the UK Electrical Forum area at ElectriciansForums.net
