MCB or Mini CU - How do you do it? | on ElectriciansForums
Discuss MCB or Mini CU - How do you do it? in the Green Lounge (Access Only) area at ElectriciansForums.net
whinmoor
Wakefield/Leeds, West Yorkshire
Reading the responses to a question on the main forum, it sounds like adding a new MCB to a fuse-board is common practice. I thought that most of us were fitting dedicated mini consumer units as standard for solar?
I think if the existing CCU has a spare way on a non RCD side of the board, or in a high integrity CCU then why install a new one? It starts looking messy when there are boards all over the place! A job i was on today aready had 5!! yes 5 consumer units in one area.
The only benefit i see is that you have not got any comeback if their lights start tripping a few days down the line!
Reply to MCB or Mini CU - How do you do it? in the Green Lounge (Access Only) area at ElectriciansForums.net
Why not fit a self contained SPD fed directly from the Henley blocks, and free up a bay? Could probably make one up from whats there, using a...
2 3 4
5K
Thanks, I was reasonably confident but nice to confirm. That was the original install getting power to the outbuilding, done by an electrician we...
