Mcb ratings | on ElectriciansForums
Discuss Mcb ratings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
R
Rajan Shakti
WHAT ARE THE SERIES OF MCB AVAILABLE IS THERE ANY CUSTOMIZE RATING AVAILABLE LIKE ACCORDING TO OUR USE FOR EG. WHAT SHOULD BE THE IDEAL MCB FOR 28a CURRENT WHETHER THIS RATING MCCB AVAILABLE
Where are you based Raj' your English is a little hard to decifer, mcb's 1,2,4,6,10,16,20,25,32,40/45,50 and 63, these are the extent of values but not all brands have all the ratings, MCCB's can come with an adjustable rating but again not all have this feature and they have ratings up into the many 1000's of amps.
What is the load your protecting here? Adding this to your previous thread i feel your stepping into an area you have little understanding in.
What is your Electrical background so we can tailor our answers to suit?
He's a fresher engineer been given an Electrical Engineer post.... ive left a post on his welcome thread regarding the depths hes getting into i hope he takes it as constructive advice.
All the standard sizes are in the 17th edition book. You could do with a copy if your going to be working out feed cables rating volt drop etc also on a side note don't write in capitals it means you are shouting.
Hi Rajan, your resume (electrical engineer) and the questions you are asking, make me feel a little uneasy, maybe to start off its better to work alongside an experienced engineer?
Reply to Mcb ratings in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
hI Gent's. I I can explain this spur line briefly, maybe someone can help me? Everything is Spur, no rings. Inside of the house and main fuse...
Just to say that the description of that safety bulb-holder does confirm if you take the bulb out, the pins are not live, even if the switch is...
