MCB, RCD & AFDD all in one | Page 3 | on ElectriciansForums
Discuss MCB, RCD & AFDD all in one in the UK Electrical Forum area at ElectriciansForums.net
Zdb
Nearly Esteemed
UK
These things are blooming huge!
[ElectriciansForums.net] MCB, RCD & AFDD all in one
Oh and ÂŁ170 :eek:
Seems these things are elusive.
Eaton are quoting ÂŁ160 per combined unit and a 16 day lead time.
They also do not do 3 phase units.
Also according to the NIC presenters, ADDS will not work on a RFC, they didn't give a very good explanation on the film they produced, but the fact that AFDDs won't work on a RFC according to them was something that stuck in my mind.
Whilst AFD's don't detect series arc faults on a ring final cct that mode of fault is not as dangerous on a ring because of the parallel path available for the load current so it's kinda swings and roundabouts....
Things can be in the regs even without a tester - after all there's never been a tester for the magnetic or thermal parts of an MCB/RCBO, only for the residual current part. Dame goes for fuses for that matter. so we have no idea if they still work when doing inspection and testing.
But if a fuse blows or an MCB trips you have test equipment to diagnose the fault quickly and reliably every time.
No such thing with these devices, one might keep tripping due to a natural arc in a circuit (something switching). How do you fault find that.... just start replacing parts at an unnecessary cost.
Reply to MCB, RCD & AFDD all in one in the UK Electrical Forum area at ElectriciansForums.net
This charger doesn't support rear entry from the looks, only bottom entry, hence that. Unless they make a white sheathed SWA, I would still need...
