MCB screw won’t undo - what would you do? | on ElectriciansForums
Discuss MCB screw won’t undo - what would you do? in the UK Electrical Forum area at ElectriciansForums.net
Winchester, UK
Curious what you would do
Screw holding ring final circuits live wires in MCB wont unscrew ,
it’s literally a ground out circle from what was originally a Philips head screw
Therefore couldn’t do end to end continuity
I did end to end from socket instead,
MCB probably needs to be changed, but I couldn’t find any new available.
probably needs whole board change unless there is an alternative compatible McB?
(Also RCD is on last legs as inconsistent results on functional testing)
  • [ElectriciansForums.net] MCB screw won’t undo - what would you do?
Think I would leave it if there was no sign of overheating.
Source a replacement breaker.
End to end from a socket proves that it is a ring.
Could have cut and jointed cable after it leaves breaker but I am not a fan of unnecessary joints.
Take the mcb off the bus bar, cut the ring conductors off the mcb
find a replacement mcb(ebay) it is an old Volex copy cu that you got there, so if you don’t find a steeple one, just use a volex they are very common
install mcb, connect ring circuit.... next!
https://www.ebay.co.uk/itm/Volex-VB...408962&hash=item42244ca4ec:g:DIwAAOSw2aJemuKB
Wasn't Steeple a Denmans own brand before they switched to Lewdens?, are the two the same?, will wholesalers ever stop pimping own brand trash before dumping it in favour of something even of even less quality?
All these questions and more may never be answered.
It’s denmans (a rebadged ge) - they don’t make that model and even used on eBay out of stock/no longer available
volex is a good shout, and might avoid whole unit change.
Only issue is RCD would also need changing
Nothing wrong with doing ring contuinity at a socket.
With the MCB, then assuming it is still making a good firm connection then I'd not worry about it too much. The only issue would be if the connection wasn't sound, then a replacement would be needed.
If the RCD is on it's way too then it's probably time for a new board anyway, at least in the near-medium future.
It does look very similar to Volex, and there are still some of those around - I have some Sector branded ones that look similar too (no 32s unfortunately) so I suspect there may be several 'brands' that fit.
If it's the same as the Series E then there are some on ebay but trying to match existing ones is always a pain and open to difficulty and is likely to only get worse as old stocks dwindle. If they could all at least agree on a standard busbar it would help.
Get a small drill bit and drill it through and use an easy out. As you guys are saying it’s probably best to be changed
It is steeple/denmans but not a re-badged GE, that was the generation prior to this one, these were made by electrium so volex would be an identical fit. I would leave it though, they're steeple boards are now made by lewden as somebody said
Thanks all
I’ve left it with client to see if they want board change, although not sure I want to inherit likely problems with house wiring
that particular circuit:
r1 was 200 ohms.
r2 1.3 ohms
rn 0.6 ohms
R1+ R2 was not too bad considering (0.5 ohms)
Reply to MCB screw won’t undo - what would you do? in the UK Electrical Forum area at ElectriciansForums.net
