M
mr brightside
Firstly hello fellow sparkies!
Secondly, can anyone tell me whether the regs define the supply side of an MCB as being the top or bottom? I always considered it good practice to define the supply side as the bottom as that is the way they are always connected in CU's, and why use two systems of wiring as this could create an electrocution hazard for maintenance personnel working on what they think is dead wiring.
I used to work on maintanance and i am an apprentice trained electrical engineer currently working for a panel wiring firm, we build process alarm systems based on Rittal cabinets with our annunciators fitted in the door.
Twice lately the drawing office have sent down customer approved drawings with the power supply MCB, which is mounted on DIN rail on the cabinet backplate, supplied from the top on the grounds that with the cabinet being top entry it's easier for the customer to connect their supply. They are usually supplied from the bottom and always have been ever since i've been there. Today i ignored the drawing and wired the cabinet supply wires out of the top as per what i would consider to be good practice. Dispite explaining my working i was overidded by both the assistant draftsman and the system test technician, neither of whom are electricians and neither of whom have passed the IEE regs course, and was instructed to rewire the MCB.
This isn't a pride issue, dispite the heirachy problem there, it's an issue of good practice. When i take it up with the supervising draftsman when he returns from his hols i'd like to be able to quote something from the regs to back myself up, i have a copy of the 16th ed. if anyone wants to refer me to a part etc. Other than that...i am right aren't i?
As long as the designer signs his part of the certificate, then the responsibility lies with him. :)
Maybe also check the MCB manufacturers website, or even email their technical department
The only potential hazard I guess you could argue would be the main switch being live on the oposite side to what is conventional. But even then its not much of an arguement because you would not rely on assumption for knowing which wires are still live. You would prove dead using the correct tools and procedure.
Whenever I have worked to circuit diagrams I have always raised questions if need be, but at the end of the day always followed the diagram.
If you deviate then its on your shoulders if there are complaints ;)
Yep you're right, i just think there should be one way and one way only.
Thanks for the replies chaps
When I was in the panel game (many years ago I might add) we followed the convention that the mains entry position determined how things were fed, i.e bottom entry bottom feed, top entry top feed. This saved on cable and space in the trunkings as cables tended not to cross each other if that makes sense.
If the Panel has a door interlocked isolator then all feeds will be dead anyway when the door is open
MCB supply side
mr brightside,
IanG1,
