Mcb to rcbo | on ElectriciansForums
Discuss Mcb to rcbo in the Australia area at ElectriciansForums.net
SparkieBusiness
Hi,
Is there an RCBO out there to replace a Nb05 5a type2 MCB?
Can't seem to find one online?
Cheers
Tyrone
you could come off the MCB into a separate RCD, but a CU replacement is far better if customer can stand the cost. remember to IR all circuits first and check for borrowed neutrals before pricing.
Just looked at a job this morning using the same MCBS.
Alterations to kintchen RFC and outside socket radial. Decided to split tails into a 2 way CU and use a couple of RCBOs.
Thought about using a seperated RCD for each circuit, but by the time i've re routed the cables through the RCDs it probably works out quicker to split tails.
Looks better too IMHO
Reply to Mcb to rcbo in the Australia area at ElectriciansForums.net
Hi, We would like to have installed new single powerpoints which are on the skirting boards of our old house. However the existing ones we have...
Here's how we generally protect circuits in the States, although GFCI breakers are also available.
