mcb trips.. | on ElectriciansForums
Discuss mcb trips.. in the UK Electrical Forum area at ElectriciansForums.net
K
kuksiani
i have install 18 way CU but im so surprised why one MCB trips every time when i switch on main switch..just one of them..he does have any problem on cable installation and not trip after i switch on again..if i switch of main switch and i switch on again that MCB trips..its brand new installation , CU and MCB..another strange problem its the consumer unit make noise..its not like usually noise of transformer do..its like PIIIIIIIIIIIIIIIIIIIIII..i never heard that before..its first time for me..any sugestion why MSB trips and why CU make noise...
i ask for help not for joking..my English probably its not academic language but i think its not a problem to understand what i ask.. thanks to any one try to help but If anyone there is nothing to say the best way its to shut up your mouth..
If the MCB trips then there is a fault in the circuit connected to it. You need to test the circuit to find the fault, since it is tripping an MCB instantly it sounds like a direct short circuit, so it should be easy to find on a continuity test.
As it is a new install this should have been caught on the inspection or testing before powering up, so repeat these again for the faulty circuit.
we try to help,but without more info what can we do?Are you an electrician,have you fitted this board,what tests have you done,where are you? we need more than a vague description of a sound to help you,there are a lot of good lads here but we are not psychic.
That's the way, polite response always get the most help :eek:mg_smile:
Reply to mcb trips.. in the UK Electrical Forum area at ElectriciansForums.net
M
I meant EIC, No idea why I put EICR down, thanks for the clarification
