View the thread, titled "MCS compatability" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
Dusty
Hi All,
After taking 2x 4mm square cables into roof void and connecting to junction box, single cable down through house and then out from a corresponding junction box near inverter back into 2x 4mm square cable to connect to inverter. The single multi core cable used gives less than 0.53 % voltage drop is this acceptable under equipment designated bt MCS standard ?
Dusty:juggle2:
Reply to the thread, titled "MCS compatability" which is posted in Solar PV Forum | Solar Panels Forum on Electricians Forums.
