MCS Standards - Jest Checking | on ElectriciansForums
Discuss MCS Standards - Jest Checking in the Green Lounge (Access Only) area at ElectriciansForums.net
SRE
Getting everything ready for Hitler arriving at 9 on Monday. Just checking the standards there's 2 versions of MIS 3002 available to download. Is it a trick question? I'd normally just have the latest version 3.2 in my trusty MCS file that I use every day! 3.1 is still there to download - why would I need to have it in my file???
You wouldn't need to have it in your file, you would just need to reference to it if the site you are using was installed to those standards, i.e. before 16 December last year.
This is why you need both:
FOREWORD
The following document [MIS 3002 issue 3.2 ] is a minor update to [MIS 3002 issue 3.1 ]. It is available for reference from the date of publication [16/12/2013 ]. Installers of microgeneration systems who are certificated in accordance with [MIS 3002 ] may commence working in accordance with this update from [16/12/2013 ]. Installers of microgeneration systems who are certificated in accordance with [MIS 3002 ] shall commence working in accordance with this update from the date of implementation [16/03/2014 ].
Reply to MCS Standards - Jest Checking in the Green Lounge (Access Only) area at ElectriciansForums.net
