In the EIC/PIR there is an entry for type of earthing (TN-C-S, TN-S etc), there is a similar question on the Test Schedual with the obvious implication that the two are different. So am I right in assuming that on the EIC/PIR the question applies to the origen (the service) and on the Test Schedule it applies to the DB being tested. and since TN-C is prohibited in the UK under Ed17, this will always be TN-S?
