ringer
Am testing a lot of tubular heater circuits in a church. All circuits supplied with MICC, which runs to SFUs then via short length of heat-resistant flex to the tubular heaters. Have tested approx 40 SFUs/heaters so far without problem - R1+R2 (dead), IR (dead), then Zs (live) on each one. However, there is one particular SFU which is causing problems. There are eleven SFUs on this circuit, ten measure out okay, just this one doesn't. I measured R1+R2 (linked at the board, measured at the SFU) and got a reading. Livened the circuit to measure Zs, but tester will not take a measurement. The heater is working - I know, because it is getting hot! There is 240V L-->N at the SFU, so the heater warms up. However, there is no voltage L-->E, so the test instrument (Megger 1552) will not take a reading.
Have checked that instrument probes are definitely touching the terminals. How is it possible that I can get a R1+R2 measurement, the heater works when powered, but there is no voltage L-->E?
Can not get my head around this one - lots of other circuits/SFUs measure out ok, just this one that doesn't. Have repeated the R1+R2 measurement just to make sure.
Left circuits off for moment until I get back to test some more.
Any ideas?
Any ideas?
