Measuring resistance of dimplex elements? | on ElectriciansForums
Discuss Measuring resistance of dimplex elements? in the UK Electrical Forum area at ElectriciansForums.net
K
Kev2632
Is it possible to measure the resistance of the elements inside a dimplex storage heater without removing the bricks, by measuring the resistance at each connector block that the elements connect into? And what readings would be expected?
Yes, it's the normal way to test if an element has gone. Following on from above posts, a 1kw element should give you around 53 ohms resi.
Reply to Measuring resistance of dimplex elements? in the UK Electrical Forum area at ElectriciansForums.net
Thanks, I was hoping someone could confirm whether it was odd or not. I've done a fair bit of insulation testing but only on a small number of...
This is an RSS feed of thread: Two electrical supplies and a single immersion element Content of the thread: Good afternoon, new joiner here with...
