mechanical protection for main incoming cable | on ElectriciansForums
Discuss mechanical protection for main incoming cable in the UK Electrical Forum area at ElectriciansForums.net
Rotherham South Yorkshire
I Have been to look at a job today. It is a flat roof garage which has been built on to the side of the house at some point and now it is being converted into a living space. The issue is that the main incoming cable for the house comes in overhead and then down the old outside skin of the house. Now the builder is planning on plastering the whole thing out however I'm not comfortable with having the DNO's cable buried in plaster.
Is there any sort of metal capping covering that I can get to protect it from the likes of screws and nails. I've had a quick look but I can only seem to find the bog standing metal capping which won't suffice.
It will be making sure its zoned as well.
https://m.youtube.com/watch?v=ii3wAtp3g3U
I've spoke to one of the members on here who works for Clarkson Evans and he said they buy it off Edmunsons.
Reply to mechanical protection for main incoming cable in the UK Electrical Forum area at ElectriciansForums.net
much more information required. Is the supply to the first building a DNO supply or a sub main cable from another building ? if it is a sub main...
Thank you for the speedy response! Have seen them on top of plaster in steel conduit before but guess it's not a common desire to have wires...
