Mechanical protection for power cable come out from ground | on ElectriciansForums
Discuss Mechanical protection for power cable come out from ground in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
F
fou73
Hi , All
am looking if there is a BS for that .
it necessary put mechanical protection (conduit ) for all power cable come out from ground
Many thanks
Welcome to the forum :)
Would the environment justify mechanical protection be provided?
If the cables are buried in the ground do they not already have mechanical protection in the form of an armouring etc?
We need more info on the set-up to answer your query, its not a blanket answer we can give.
Reply to Mechanical protection for power cable come out from ground in the Electrical Wiring, Theories and Regulations area at ElectriciansForums.net
It might be ok
The total current capacity of the system in amperes is the same as the per-phase rating when referring to a balanced three-phase system. Thus, a...
