P
Piratepete
Hi Guys
I have to install an 80 Amp supply to a new CU in a Church extension 22 metres from the main Dis Board. The route follows the back of the church generally hidden under pews all surface mounted. I do have to feed it through an 800mm stone wall.
I could use a 3 core 16sqmm SWA XLPE cable, but this size is going to be a sod to deal with.
The alternative is to use 16sqmm tails (or even T&E) with a seperate 16sqmm earth wire alongside. In this situation do I need to provide any protection to the Earth conductor?
Cheers
Pete
Cheers
Pete
