Just out of interest, how many steel capping lengths stacked on top of each other would you consider to be suitable to provide mechanical protection to switch drops on non-RCD protected lighting circuits?
I've always been lead to believe that 3mm of steel is thick enough to be defined as mechanical protection against screws and nails which by my measurement would make it about 5-6 steel capping lengths stacked. Would you stack more or less? Would you even consider it suitable?
And before you mention it, lets say for example that steel conduit is out of the question.
Debate...
Debate...
