Mechanical timer | on ElectriciansForums
Discuss Mechanical timer in the DIY Electrical Advice area at ElectriciansForums.net
Norway
Hello.
I got an old venner mechanical timer and need some advice. I need to connect it to a unit, how would one do that? It is a, b and c outputs. Wich to use?
Thanks for help.
Permanent live to rhs clock permanent neutral to other clock terminal, this will keep clock going.
And guessing..
Live to C and either A or B will become switched live when on or off (when A is on B will be off and vice versa) Choose whichever suits what you're doing - if it's on when it should be off swap B with A.
Do check for continuity with a test meter before you connect mains to it, just turn clock until it clicks and measure between C and B (or C and A)
Reply to Mechanical timer in the DIY Electrical Advice area at ElectriciansForums.net
Elkay 2235A-1 Energysense White 3 Wire Touch Timer 16A 240V. This is a touch timer (you don't need that bit) which also can be activated by a...
Hi All, I have recently purchased a motor soft starter from aliexpress for a 3 phase motor Before connecting load I measured the input and...
