Megaflo UVC - Very Loud Noise When Hot Tap Opened Hi,
I have noticed that when a hot tap is opened for the first time after a heating cycle (in this case a bath tap), the water flows for a couple of seconds and then there is a very loud noise as can be heard in the video.
Any ideas what it may be? I couldn't deduce the source. The EV was recently checked and pressure increased from 1 to 3 bar per instructions but notably it did this before. I just at that time didn't know the trigger. It hasn't always done this however, probably the last couple of months or so.
Thank you.
Megaflo UVC - Very Loud Noise When Hot Tap Opened to read more on the original thread at Plumbing Advice
See also UK Plumbing Advice for all UK plumbing advice needs.
Thank you.
