Hi all.
Plumber has installed a Megaflow unvented system with a neutralizer and a back boiler working off a stove. We've been discussing how to wire it up electrically and I wondered if anyone has experience/ could direct me to a wiring diagram?
The stove was trial run and gravity was not causing the heated water to rise properly so a small pump has been added. An initial thought was to use a stat to 'sense' the pipe heating up to start the small pump to help gravity along, but this needs to then stop when the tank comes up to temperature and the motorised valve and main pump 'kick in'.
Megaflow won't help as they say their tank shouldn't be used with this set up but the plumber considers it OK as a neutraliser has been installed?
Constructive thoughts welcomed...
