Hi, I have a ‘05 Megane ii 2.0 with a f4r, and I was wondering if anyone has any info regarding wiring a bee r rev limiter up to them
I only need the crank signal
I used a 1000v 1A diode stopping the current from flowing towards the coils, and I tried connecting the crank sensor wire either engine rpm speed sensor wire, but the bee r still does nothing.
I'm about 90% sure it's an issue with the crank sensor side. Is it because it's a 2 wire hall effect sensor? And how would i extract a pulse signal from this sensor?
- TL;DR
- Bee R compatibility with hall effect sensors
