Megger 1552 instructions say "Rechargeable batteries must not be used"? | on ElectriciansForums
Discuss Megger 1552 instructions say "Rechargeable batteries must not be used"? in the Electrical Tools and Products area at ElectriciansForums.net
DomB
Hi, does anyone know why Megger insist on no rechargeable batteries in their MFT 1552? It explicitly mentions it in the instructions there..
Cheers
Malc beat me to it, but they are offering free rechargeable batts and charger with the Meggers on a couple of inline stores.
i use rechargeables in mine no probs. only thing with them is they die suddenly, not slow drop off of volts like alkies. as long as you got spares, in case they die in middle of testing, OK
Which rechargable are you using tele?
At the minute its only cost ÂŁ1.60 per battery refill on my Megger which can be added to every job anyway.
I have spoken to the engineers at Megger and the reason for saying you should not use rechargeables is nothing to do with instrument accuracy - they make no difference to the instrument readings. The reason is a "backside covering exercise" on the basis that rechargeables can put out a huge current compared to alkalines if they are shorted out so if something went wrong in the MFT that shorted the batteries it could melt some stuff inside and kill the product.
I mentioned that I put rechargeables in everything from my TV remote to electric toothbrush without any worries and they said that it was up to me what I put rechargeables in, but due to the high short circuit current and the risks that involved they would not recommend their use.
so why are megger's own rechargeables safe then? is it a pack with a fuse incorporated? i thought that the instrument had a built in battery fuse
aye, and I've not noticed anything else, toys etc, say you can't use rechargeables. I guess there's a higher chance of a short on a tester?!
One online wholesaler is selling it with a pack and charger from a radio controlled car. A trickle charger thats take 12 hours and they also state theres no cut out when the batt pack is charged.
Think i'll stick with standard AA rechargable or not for the time being
Reply to Megger 1552 instructions say "Rechargeable batteries must not be used"? in the Electrical Tools and Products area at ElectriciansForums.net
Hi Richard Thanks for the reply, it won’t function as it will with the MFT1741+ but will I be able to use the MFT 1721 and perform all the...
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
