4x4 mark
ive had my megger for just short of a year and today after changing a consumer unit i got a strange reading when testing the rcd trip times.
it will not auto test, ie run through the test sequence by itself, it just displays >50v. if you take each test on its own it will 1/2 test 1x test and ramp test but it will not 5x test just shows same message.
i know you can change test voltages between 25v and 50v but i assume that the megger is at fault as it seems to do this at the output side of the rcd as well as a socket. is this the megger not putting the test voltage out to the circuit, yes the circuit is energised, i also tried changing the batteries but still the same.
cheers mark
cheers mark
