megger 1730 mft | on ElectriciansForums
Discuss megger 1730 mft in the Electrical Tools and Products area at ElectriciansForums.net
Error Code 29 relates to a internal power supply fault. It's more than likely that the AA NiMH batteries have reached the end of their serviceable life which will need replacing with cells rated to at least 2000mAH.
If the batteries are fine, you will need the unit repairing as the fault is by an internal component failure. If it is listed on eBay, chances are that it has been damaged in use and you should budget around ÂŁ200+VAT for a repair.
Reply to megger 1730 mft in the Electrical Tools and Products area at ElectriciansForums.net
Hi Richard Thanks for the reply, it won’t function as it will with the MFT1741+ but will I be able to use the MFT 1721 and perform all the...
Hi, did you decide to upgrade your test meter? If so, how are you finding it?
