Megger CM400 multifunction tester. | on ElectriciansForums
Discuss Megger CM400 multifunction tester. in the Electrical Tools and Products area at ElectriciansForums.net
sparkdog
Sunny Sussex
Does anyone know if the Megger CM400 has an auto RCD test facility?Its hard to tell from the data sheet if its the CM400 or CM500 that does,or both.
Reply to Megger CM400 multifunction tester. in the Electrical Tools and Products area at ElectriciansForums.net
KT66EVA (KT66DL & KEWEVA) - ÂŁ1073.60 + VAT if you shop about as a combo
Hi Richard Thanks for the reply, it won’t function as it will with the MFT1741+ but will I be able to use the MFT 1721 and perform all the...
