Megger mft 1502/2 | on ElectriciansForums
Discuss Megger mft 1502/2 in the Electrical Tools and Products area at ElectriciansForums.net
i have the 1552, which is similar. fantastic piece of kit. easy to use, and doesn't come in a JCB digger box.
Yep got a 1553 thats the bluetooth version of the 1552 I like it but wasted money on the bluetooth version.
And I keep it in a Fluke carry case.:clap:
I have the exact model you mention, the 1502/2. It's the one before the 1552, and the one feature it doesn't have is the Auto RCD test cycle, so you have to change the MA and waveform setting yourself. This means you may have to do a bit of walking from resetting the RCD back to the tester. Otherwise, it's a very solid, usable tester.
What he said. Except I have the 1553 bluetooth model
If your not fussed about the auto RCD test then it's a great piece of kit! :)
Reply to Megger mft 1502/2 in the Electrical Tools and Products area at ElectriciansForums.net
Hi Richard Thanks for the reply, it won’t function as it will with the MFT1741+ but will I be able to use the MFT 1721 and perform all the...
Well that mean to either send it off to megger or I would us calabration Manchester ask them.
