Megger MFT 1552 what is the red probe used for? | on ElectriciansForums
Discuss Megger MFT 1552 what is the red probe used for? in the Australia area at ElectriciansForums.net
if u mean the big chunky red probe its used so u onli need 1 hand when testin there is a button on the probe which works as the test button so u dont hav 2 struggle tryin 2 hold all the normal probes and press the test button on the meter
hope this helps
Shane
Funny :)
First I tought it had
to be something with direct current messureing,
I notice while testing that it test automatic when it detect voltage ,
haha like it, looks a bit clumsy.
Is it typically used for the insulation testing?
Funny :)
Yes only really for IR testing as the rest of the tests start automatically when leads are connected.
Never used it myself yet apart from 1 time when i used the light on it.
Reply to Megger MFT 1552 what is the red probe used for? in the Australia area at ElectriciansForums.net
Yes that was me. If you change your mind give me a shout and I’ll sort something out for you 👍
Aico use the term Megger on their CU stickers
