R
rednex
hi, just after some advice regarding a megger 1502 that reads 1v on start up. could this just be a calibration issue (last calibration 11 months ago) or a possible fault. battery good 12.2v. many thanks. j
Discuss megger mft1502/2 reading 1 volt when no voltage applied in the UK Electrical Forum area at ElectriciansForums.net
Hi, thank you for your reply. You don't happen to know of the outcome do you? I can't find the other thread. Thanks. Jthere was a thread exactly the same some time ago.
Hi, thank you to everybody for your replies. I contacted megger who reassured me that this is not an issue. The meter is purely designed to measure supply voltage and is not accurate at low voltages. Thanks again. JGoogle "megger mike", he'll sort you out.
Reply to megger mft1502/2 reading 1 volt when no voltage applied in the UK Electrical Forum area at ElectriciansForums.net
