Megger MFT1721 FUS fault code | on ElectriciansForums
Discuss Megger MFT1721 FUS fault code in the Electrical Tools and Products area at ElectriciansForums.net
Today i had the megger dropped from a meter height and is now showing the FUS code.
Checked the fuses, Both are good. Contacts look very good. New batteries installed but still get the same code. I did the reset just in case but no results.
This Megger is not in the warranty, is quite old and used. So now i tried to open it just to check if there is any wire, fuse or something visible lose caused by the drop.
My issue how do you open it ? Looks quite cumbersome and difficult. Anyone tried to open it ? I search to find somebody who did that but cant seem anyone open one yet ?
  • [ElectriciansForums.net] Megger MFT1721 FUS fault code
Tel will be along shortly no doubt with a method involving a hammer ?
screws in case visible top and bottom. other screws behing front panel stick-on. peel off carefully to reveal screws. then you can split the case.
Ok opened it. Looks like its a part came of from the pcb...weird because was solder on pcb...
@Tel there are no screws under the sticker.I remove only the bottom 6 screws and pull out the lead contact panel and came out like a candy bar
A surface mount mechanical relay. Looks like you may have been lucky and it may not have ripped the pads/tracks off the PCB.
Resolder it, carefully, and check for any other damage. Looks like it went with quite an impact!
my bad.was thinking it was same as the 1552/3 types.
Reply to Megger MFT1721 FUS fault code in the Electrical Tools and Products area at ElectriciansForums.net
Did you turn off the power to the oven for a long time? Comments on the web suggest that a power cycle to do a 'reset' should be from 15 to 60...
Long shot, but looking at the previous posts. hope i have understood correctly. 1. continuity between live and earth 2. no continuity between...
