Megger MTF test leads | on ElectriciansForums
Discuss Megger MTF test leads in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Hi all, Anybody knows are there some cheper alternatives out there? With croco clips and all. The original ones are ÂŁ30 and they dont really last. Thanks!
Get used to the reality of replacing test leads.
My Metrel has two types, they last about 12 months and they cost about ÂŁ70 to replace!
Don't try and hang on to old ones - in my experience they can give out rather unreliable and misleading readings!
The GS38 leads with 4mm banana plugs, are widely available, Kewtech are probably the best currently available. The BS1363 loop lead with the 'Megger special' 3pin plug, is unfortunately manufacturer specific as far as I am aware. Does anybody know which manufacturer makes/supplies this type of plug to Megger, LEM and others.
Reply to Megger MTF test leads in the Periodic Inspection Reporting & Certification area at ElectriciansForums.net
Having some issues with my companys fluke 1662/1663 tester. Zeroing 2 leads for continuity test we get the value 0.08 which is expected. The issue...
Personally it would annoy me having to use adaptors all the time. Can't you buy a proper UK one?
