B
Bill avoider
I am planning to Meg a 480 volt 3 phase motor leads to ground using 1000 volts DC. What are acceptable ohm values and when should I be concerned.
Discuss Megger readings in the Commercial Electrical Advice area at ElectriciansForums.net
I take it from your location you are an American, what does you NEC recommend?
Pete I am from Quakertown PA . You are in the Lehigh valley? I will check the NEC. I am hearing anything under 500 ohms is trouble.
Reply to Megger readings in the Commercial Electrical Advice area at ElectriciansForums.net
