Melty goodness :D | on ElectriciansForums
Discuss Melty goodness :D in the UK Electrical Forum area at ElectriciansForums.net
D Skelton
Mentor
Nearly Esteemed
Milton Keynes
Can anyone else explain how three MCB's could get fused together like this? And when I say 'fused', I mean even ramming a screwdriver between them couldn't break them apart!
My thoughts are a loose/incorrect connection to the busbar. Mind you, you'd have at least thought they would have tripped long before reaching this state.
Also, note to any of you who come across anything similar, bag it up before it goes in the van otherwise it'll stink to high heaven of the worlds worst and most pungent smell for weeks!
[ElectriciansForums.net] Melty goodness :D [ElectriciansForums.net] Melty goodness :D [ElectriciansForums.net] Melty goodness :D
If the load is too high then the CB should have tripped but I would like to look at the bus bar to see if the cb connections to that were really tight and in the right place. mind you I like "Oldtimers" idea best. There could be an internal poor connection in the CB.
it's either a bad termination or a possible recall MCD by electrium. if the latter, get the batch number off the mcb, and then claim through the electrium recall scheme.
I must admit I haven't paid that much attention as of late. 1. I've been too busy, and 2. A massive influx of keyboard warriors recently hasn't inspired much confidence in me to keep active :(
note to self, I must pay more attention! :6:
Reply to Melty goodness :D in the UK Electrical Forum area at ElectriciansForums.net
