J
James Sutton
Hello All
Ive rang up a local electrical wholesales for a MEM Type c 40A 3mA RCBO they sent over a picture of a 40A MCB with a bottom piece to connect in the MCB to make the RCBO. Has anynoe ever used these? normally ive used the Merlin Gerin. The RCBO is to replace a 40A mcb supplying a shower in a commerical building. Also when i come to test the tripping times where is this best down at the dis board onto the RCBO terminal. Iam using a Megger 1552 tester with the 3 lead options. Normally i use the plug adaptor to test sockets on an RCD cct. But where i work in commerical buildings we tend not to use RCD as much as domestics.
James
James
