Hi all,
Hopefully picked the right place to post about this..!
I've just completed an EICR and there was a second board mounted to the water cylinder which does both the hot water and heating.
It's in an apartment (I'm assuming every flat will be the same).
I've told the landlord that I need to come back to test this board and that it's probably not going to be good news for them.
Has anyone come across something like this before? I just can't see how it was ever acceptable the way it's been mounted! I haven't properly gotten to the board yet as it has shelving built infront which needs removing.
The contactor inside has a couple of brittle/burnt cables so some investigation work is going to be required.
Some info on the board:
16mm 3 core SWA supply fed from 63A MCB
1361 fuses supplying immersion, pumps and valves
Contactor inside
Water pipe directly above
I've scrubbed the company name off one of the images so I don't drop anyone in hot water ahem.
I'm finding myself coming across loads of bizarre installation methods recently and it's driving me mad so any advice on where to go with it moving forwards would be appreciated!
Thanks.
Contactor inside
Thanks.
- TL;DR
- Dis board mounted to hot water & heating cylinder - where to start?
