Memera 2000 replacement rcbo | on ElectriciansForums
Discuss Memera 2000 replacement rcbo in the UK Electrical Forum area at ElectriciansForums.net
South East Kent
Afternoon,
I need to change a memera 2000 6amp mcb for an rcbo that is compatible . I believe the mentioned mcb are not made anymore. Anyone got any suggestions ?
You can use memshield 2 range MCB, with a MR30 pod (according to Eaton when I contacted them in 2019). The pods (they are a field kit that clips on to the MCB to create an RCBO) are stupid expensive. If this is for additional protection, I would fit a powerbreaker RCD spur next to the CU and wire the circuit through that.
Also E-Bay has an amazing amount of breakers of all types and ages on it, sparks have collected them and stick them up for sale. The only down fall would be if the thing works when you get it, a gamble for sure but E-bay is good for rare items
Reply to Memera 2000 replacement rcbo in the UK Electrical Forum area at ElectriciansForums.net
I wonder if a double row Fusebox would fit in there…
Theres an FCU feeding external electric gates, an intruder alarm and I'm guessing more than 2 lighting feeds. It's been reported to the client and...
